Digital receptionist's "Launch Script" option Path
maisx
The minimum permissions you have to give on Linux is at least read and execute for user phonesystem.
chown phonesystem test.sh
chmod 500 test.sh
So it will be like that
-r-x------ 1 phonesystem root test.sh
Ok, thanks for the reply
the position of the script can go well on path /var/lib/3cxpbx/rtest1.sh ?
TKS Maisx
Please ask someone can give me an example of sh scrip for linux
thanks a lot MAISX
TKS Maisx
Hi @maisx
Yes it can be in that path you mentioned, the system works based on a full path to go find and launch the script.
As for script examples, these are typical bash scripts that can return exit codes, and based on the exit code you can select what action you want the PBX to perform. You can read up on bash scripts on Google. The system does not know what the script does, it just reads the exit code.
Call_Flow.co.uk
