seanrhudy Gold Partner Joined Nov 16, 2020 Messages 16 Reaction score 0 Nov 16, 2020 #1 Hello, is there a way to remove the ability for callers to cancel the voicemail before they hang up?
JohnS_3CX Support Team Staff member 3CX Support Joined Jan 4, 2019 Messages 14,560 Reaction score 3,728 Nov 17, 2020 #2 Hi Sean, No, the voicemail menu is standard. You can change the audio prompts though if you don't want them hearing their options, and simply leaving a message and hanging up should work fine.
seanrhudy Gold Partner Joined Nov 16, 2020 Messages 16 Reaction score 0 Nov 17, 2020 #3 Thanks John. Where can I change the audio prompts? I don't see that under Voicemail settings.
JohnS_3CX Support Team Staff member 3CX Support Joined Jan 4, 2019 Messages 14,560 Reaction score 3,728 Nov 17, 2020 #4 In your PBX Settings > Prompts > Manage Prompt Sets You can make a copy of the prompt set, and edit the one called RECYAMSG You will have to enable this as your default prompt set for the PBX, and individually under each extension's Voicemail. Reactions: digitaldoctor
seanrhudy Gold Partner Joined Nov 16, 2020 Messages 16 Reaction score 0 Nov 27, 2020 #5 This worked, thank you for the help.
JohnS_3CX Support Team Staff member 3CX Support Joined Jan 4, 2019 Messages 14,560 Reaction score 3,728 Nov 30, 2020 #6 Glad to be of assistance!
