Disable RPS in v18 - Workaround for Yealink phones
jeff_tech_services
Platinum Partner
I recently ran in to an issue with a client using v18 and Yealink T46U phones. We always prefer to use Yealink's YMCS/RPS services, as the endpoint control is far more feature-rich, but v18 doesn't have an option to disable the RPS relay service. So, here's the workaround I was able to figure out:
Step 1: I added the phones as router phones to the appropriate extension in the 3cx webclient
Step 2: I used the RPS removal tool from Yealink at ticket.yealink.com and deactivated the RPS link between the 3cx RPS relay and the phones
Step 3: I added the phones to Yealink YMCS and RPS (without errors this time, as initially I was getting a failure because 3cx was already registering the phone to it's own RPS service)
Here you go! Hopefully this saves you some time! :)
Hi Jeff,
Keep in mind you can easily turn RPS on or off in V20 with a single click below, and new phones will not cause the system to send new RPS entries.
Hi Jeff,
Correct, v20 makes this an easy to disable feature, but many struggle with finding a solution for v18.
Finatra.us
