Disable Use of 3CX Softphone for Extension
tony28
Forum User
How can I prevent an extension from using 3CX softphone?
Enabling Disallow use of extension outside the LAN" still allows it to connect.
Block tunnel connections in the extensions settings
I cannot because that would also block the IP phones which is using SBC
Simply prevent them from knowing it exists so they can't install it?
isn't the sbc tunnel not affected by extension tunnel settings?
Don't give them the password, how will they provision the softphone?
Welcome email. I prefer if I can turn the softphone off or on.
The welcome email can be edited in Settings -> Email -> Templates.
And I do agree that an independent switch would be great but try disabling the tunnel on one extension and see if the SBC is affected.
bosdorf
