Disabled Calls transferred from voicemail will be routed here
luckystrikes
I am sure I am missing something but I uncheck this in the system settings but the caller still was able to press * from a users VM box and go to the operator extension.
Is there another place to disable this or maybe I need to check voice prompts properly remove this?
You can disable the routing to Operator from the below option:
DejanMDS
