Disallow use of extension outside the LAN Disabled on all extensions
AMistich
Forum User
Like the title says, just recently I found that all my extensions now have Disallow use of extension outside the LAN disabled. I cannot find any global setting to turn this back on for all extensions. Is there some way of doing this or do I have to go into each extension to correct this? Currently I am not running any SBCs or have any remote phones.
You do not have to enable this for SBC provisioned phones, only if stun configured.
If you have no sbc or stun phones, you do not have to untick this
3CX apps use the 3cx tunnel setting
Basically for security reasons, none of the extensions should be used outside of LAN. When my PBX was set up all extensions had this option enabled since none of my phones are SBC provisioned or use STUN. At some point this was automatically disabled, and I would like to enable it so none of my extensions are allowed to be used outside of the LAN.
Ok so stupid me just figured it out. I didn't realize you can select all extensions and then edit
Which opened up the ability to enable that option.
Netflo
