Solved Disconnected. Waiting for network.
RogerH
We have this occasionally crop up. It may be worth doing a soft reboot of the server.
Then clear your cache and see if that works.
Sorry not sure why the signature is not resizing the images.
I did restart all the 3cx services but the issue remained. I will try a server reboot tonight.
Hi Roger, please check the extension provisioning section, under 3CX app, ensure "Block Presence information in 3CX Apps / Webclient " is not enabled.
Also note you must check this using Google Chrome, not other browsers as they are not officially supported for the Webclient specifically.
Reactions: cwoller
Rebooted server and its now all working as expected.
Checked "Block Presence information in 3CX Apps / Webclient " and it was not enabled.
I was using Google Chrome too.
Thanks to all for your help.
Hi Roger,
I'm glad it was resolved
Roman Mazur
