Solved Displaying ext number from history (WQ settings)
Ludovic
Hi there,
I've some agents in a WQ, with a SDA linked to it.
These users receives all the calls from this WQ.
All of them are using a Yealink T46S, in the Call history of the phone I would like to display the number of the caller. Instead if this I have the name of the WQ..
Can someone explain me how to fix it ?
Cheers !
Hi @Ludovic
When you press to see the details of the call, doesn't it show the number that was calling?
Hi JohnS,
Yes it does, but I want to display the number first. Is it possible ?
In your management console go to the Contacts section.
There you can click options and you can choose one of the below methods of displaying the ID:
10229
Thanks for the info, It's working !
Glad to help!
GP Concepts
