DND on T46S
greatchoice
Trying to find a way to permanently disable the DND button. I can log into the device and remove it but every time I change the firmware or template it comes back. Is this an enterprise feature on custom templates? Anyone have this concern?
I prefer to educate my end users but yes, you can use a custom template to disable it, or you can provision the phone and then remove the provisioning URL which will stop the phone from re-provisioning. Then any changes you make in the web interface will stick.
You don't need any specific version to do custom templates, although you can't use custom templates with 3CX hosting.
https://www.3cx.com/docs/custom-ip-phone-templates/
[email protected].
