Solved Do I need to care about this message?
AWS2P
by hasard today I noticed on one V18 PBX running on OVH cloud a list of messages always the same, do I need to taake care about this?
example :
09/30/2021 5:48:55 PM - Exception: DialogUsage::Exception Can't provide an answer @ ServerInviteSession.cxx:501
09/30/2021 5:07:53 PM - Exception: DialogUsage::Exception Can't provide an answer @ ServerInviteSession.cxx:501
09/30/2021 4:16:44 PM - Exception: DialogUsage::Exception Can't provide an answer @ ServerInviteSession.cxx:501
09/30/2021 4:16:19 PM - Exception: DialogUsage::Exception Can't provide an answer @ ServerInviteSession.cxx:501
If this is something important, what do I need to search for ?
Hi Vasilis,
thanks for quick answer, ok so if i understand well, this kind of message should be hidden in log and until now they are not , BUT if there's no problem on pbx then I can ignore them.
So problem vanished ;)
Reactions: VasilisV_3CX
Right you are @aws2p. Glad this helped.
Rich Hopkins
