Does 3CX StartUP work with VOIP.MS SIP provider.
bobmcm461
New User
I had a local 3CX setup on a Raspberry Pi that was working fine with VOIP.MS. All of a sudden the setup stopped working. I have since found out that Raspberry PI is no longer supported and I suspect that this is the cause. I am trying to setup a 3CX StartUP, but it does not let me setup VOIP.MS in the Office Settings:Voice & Chat:Add Trunk options. Is there another way to setup this Trunk with 3CX StartUP?
Regarding your question and VOIP.MS, please note that this provider is not supported in the startup version.
The supported providers are listed in the drop-down. You may use one from this list.
Or you use a 3cx dedicated hosted instance where VOIP.MS is an option.
awan05
