Door Entry Systems - any experience?
Daniel Ward
We are looking for a door entry system to work with 3CX, anyone have first hand experience with setting these up? Our requirements are it needs to be code entry and intercom system.
If so, what did you end up going for?
There is a range of compatible ones we've seen, but nothing specific jumps out.
https://www.3cx.com/sip-phones/
If those don't "fit the bill", you can always think about going with an ATA in combination with an analogue system. There tend to be more of those available.
We have clients running 2N units without any issues, have to provision them manually but this is very easy - https://www.2n.cz/en_GB/
One client is running Fanvil i20S , again provisioned manually.
Interesting device. Is there a way to open a gate through the door phone? Perhaps by sending a DTMF key? The door phone than would activate a relay wired to the gate lock.
In this way it could completely replace old analog systems...
This is what we have done, using one of the line keys we have program it with the correct dtmf code to open the door / gate.
So the person answers the call, and presses the correct blf key
WagnerFT
