Dot in the property avoid to evaluate value
ado2000
SOHO User
Hi, I'm integrating our CRM with 3cx, our json contact have this format.
"items": [
"id": 4533277,
"properties": {
"AmContact.name": "Name",
"AmContact.surname": "Last name",
"AmContact.telephone": "3452345",
"resultCode": 0
when I try to get the id value by using values.id it gets correctly the value.
but if I try to get the name in this way values.properties.AmContact.name I get non value
i also tried values.properties.[AmContact.name], values.properties.['AmContact.name']
what's the correct syntax
Hmm, the fact that your properties have dots will probably screw all of that up.
Normally, you'd use "items.id" as rule, then "items.properties.AmContact.name". Array syntax won't work for sure.
Hi ConceptWeb, thanks for the reply,
to have a dot in the property name is not so common but can happen, the question is: is it possible to escape the dot in property name or not?
how 3cx evaluate the json ? for instance jsonPath can manage this syntax
The property path in 3CX isn't the property path you're showing here. They use their own parser.
@edossantos should be able to tell you how to access those properties, if even doable in 3CX directly.
Reactions: ado2000
No, you will not be able to escape the dots, that JSON response will not work unfortunately.
Thanks Ernesto,
solved doing a custom api for 3cx.
footandankle.my3fcx.us
