Downgrade 3CX
thomas1234
Hi there,
Our 3CX subscription expires in 2 weeks. What is the best way to downgrade from 16PRO > 8PRO?
We are currently using a FQDN, however there is no need for the FQDN anymore. Happy to use the standard 3cx domain going forward.
We do not use a reseller. bought directly.
Customer portal seems to have bugs.
9546
The best way is to buy a new license 8PRO and than backup the configuration of the 16PRO with the flag "Include License Key Information & FQDN" unchecked. There is no way to downgrade a license from 16PRO to 8PRO with the same license in the 3cx world.
regards
Reactions: accentlogic
@thomas1234
You don't need to backup and restore. You can replace the key without reinstalling.
You can continue to go direct but working with a partner gets you helpful little tidbits like this for free with no extra cost to you.
GothamUser
