Download 18.0 (build 20)
WeCanConsultngSpa
I need to download version 18.0 (build 20): where can I find it? With the builder 18.0 (build 32) I have problems with a sip trunk; I also tried with v20 but there are no sip trunk customizations available.
You will have the same problems with build20. In V20 you still can customize your trunk. What ist the problem? What trunk are you using?
An ad hoc personalized trunk from a TLC operator; between the two versions I receive the proxy authentication request even if it is not set in the gui. Do you have the 18 build 20 ISO available?
There are no ISO with a special version. Its netinstall. So v18 or v20 is possible. Next time make a backup before update.
sambannoura
