Dropped calls
Matt_AIT
We have been experiencing issues where inbound calls drop 1 second after being answered. We are using the new v18 app with Jabra headsets. A restart of the PC will fix the issue.
Hi @Matt_Alcom_IT,
Does this only happen with Jabra headsets? Do calls not drop when not using the integration? Does this happen for internal calls as well?
Hi @Matt_Alcom_IT,
I've asked one user to uninstall Jabra Direct and disable integration. I have also requested one user us the web client. Yes, it also happens to inbound calls.
Hi @Matt_Alcom_IT,
Does the call hang up after 1 second for ALL calls (every user using Jabra integration)?
What is the call flow for the calls that drop?
If you dial internally (extension A to extension B), does the call end in 1 second?
Hi @Matt_Alcom_IT,
The call drops after 1 second for any affected user. We have 4 or 5 staff on a call queue and it may happen for extension A and no-one else. I have noticed that some of the dropped calls may drop at 8 seconds.
So caller A calls, queue rings, extension A answers, and the call drops at 1 second. If another call comes in, extension B can answer successfully. However, if a third calls come in and extension A tries to answer it will drop until they reboot.
All staff has the Jabra integration setup (though I have asked one to disable to test).
When the issue is occurring an internal call from extension b to a would drop.
Hi @Matt_Alcom_IT,
Okay thanks for the update. I'll wait to hear from you if it happens with Jabra integration disabled / uninstalled.
Hi @Matt_Alcom_IT,
So far the user who has disabled Jabra integration and uninstalled Jabra direct has not had the problem. However, the issue is sporadic. I have asked them to monitor for another few days.
Reactions: VasilisV_3CX
Great @Matt_Alcom_IT, thanks again for letting me know. If this happens again, and is reproducible I'd be happy to jump on and take a look.
We have been able to reproduce the issue and capture it. Would you like to take a look at them?
The other user, who has disabled the headset integration has still not had the issue,
Update: Still being investigated. The issue is specific to the Desktop App using Jabra Integration only.
Awaiting additional logs via PM.
megalmazan
