DTMF input not working on IVR
Beuningen IT
Hi there,
Just received a complaint from one of our customers. Not sure what's going on, but sometimes people which are calling the customer through a mobile phone (iPhone) a DTMF input is not being recognized and after it should automatically redirect the call to a ring group. This however also fails. Please see the attached video. Really strange issue. Below is the log from that specific call.
Code:
05/03/2023 1:53:31 PM - Leg L:5760.2[Ivr:800] is terminated: Cause: BYE from local
05/03/2023 1:53:31 PM - [CM503008]: Call(C:5760): Call is terminated
05/03/2023 1:53:31 PM - Leg L:5760.1[Line:10001<<+316xxxxxxxx] is terminated: Cause: BYE from xxxxxxxx:5060
05/03/2023 1:53:13 PM - [CM503007]: Call(C:5760): Line:10001<<+31683199924 has joined, contact <sip:[email protected]:5060/UDP>
05/03/2023 1:53:13 PM - [CM503007]: Call(C:5760): Ivr:800 has joined, contact <sip:[email protected]:5483/UDP>
05/03/2023 1:53:13 PM - L:5760.2[Ivr:800] has joined to L:5760.1[Line:10001<<+316xxxxxxxx]
05/03/2023 1:53:13 PM - [CM503002]: Call(C:5760): Alerting Ivr:800 by contact <sip:[email protected]:5483/UDP>
05/03/2023 1:53:13 PM - [CM503025]: Call(C:5760): Calling T:Ivr:800@[Dev:sip:[email protected]:5483;rinstance=64cdfa793163b606] for L:5760.1[Line:10001<<+316xxxxxxxx]
05/03/2023 1:53:13 PM - [CM503027]: Call(C:5760): From: Line:10001<<+316xxxxxxxx ("xxxxxxxx" <sip:[email protected]:5060>)  to  T:Ivr:800@[Dev:sip:[email protected]:5483;rinstance=64cdfa793163b606]
05/03/2023 1:53:13 PM - [CM503004]: Call(C:5760): Route 1: from L:5760.1[Line:10001<<+316xxxxxxxx] to T:Ivr:800@[Dev:sip:[email protected]:5483;rinstance=64cdfa793163b606]
05/03/2023 1:53:13 PM - [Flow] Call(C:5760): has built target endpoint: Ivr:800 for call from L:5760.1[Line:10001<<+316xxxxxxxx]
05/03/2023 1:53:13 PM - [CM503010]: Call(C:5760): Making route(s) from Line:10001<<+316xxxxxxxx to <sip:800@xxxxxxxx:5060/UDP>
05/03/2023 1:53:13 PM - [CM503001]: Call(C:5760): Incoming call from Line:10001<<+316xxxxxxxx to <sip:800@xxxxxxxx:5060>
devo.it
