Dynamic CallerID base on DID
myTell_Global
SOHO User
I want to develop a solution to check the DID then based on each DID add prefix to the caller's callerID, in this way, when I want to redial the received call, the caller will see the number which is dialed.
@myTell_Global Developing a custom Caller ID tool requires significant resources and a dedicated development team. This process includes first building an API and then developing the Caller ID tool itself.
Instead, we can offer you a Dynamic Caller ID Tool that we have already developed, which is fully functional and reliable. With this tool, you can:
  • Set Caller IDs based on specific departments.
  • Choose between manual Caller ID changes or dynamic changes, where the Caller ID updates automatically after every call for the user.
If you'd like to see the tool in action, you can visit our website or email us to schedule a demo.
Email: [email protected]
Website: www.thetelephony.co
Simply name the DIDs and enable the appending/prepending of the DID name. Easy and free (built-in.)
Otherwise, this can be done using a script quite easily. No need for third-party tools.
Yes indeed @ConceptsWeb or choose a VoIP provider that properly passes e164 numbers in the first place. Twilio will do this for example.
BConveryCoreCare
