Dynamics 365 not popping up or journaling
reynolwi
I have Dynamics 365 completely integrated into our 3CX. It is authorized, set to always query, and all the options are enabled for journaling and contact creation. When using the test button, it is searching correctly and returning valid results. Our 3CX is also correctly authorized and integrated with Microsoft 365 so extension users are matched to the correct dynamics 365 user.
In PWA, under Settings and Integration, it is set to "Open Contact URL using Server Side CRM Integration"
In PWA, if I type in a phone number to call, it is actively searching dynamics crm and finding valid contacts, showing the CRM initials over the contact image placeholder. If I click on a phone number in Dynamics, it is calling with Click 2 Call through 3CX and it triggers a Call Activity log entry pop-up.
On inbound phone calls into 3CX, nothing is happening. Nothing is triggering Dynamics to pop up with a new lead or call activity log. It just sits there. There is also no lookup option under the phone number. I have searched and scoured but I must be completely overlooking something.
Can someone point me to the right resource that I must of overlooked?
What is this setting in Admin > System > Phonebook > Options set to?
Hi @reynolwi,
When the option "Open Contact URL using Server Side CRM Integration" is selected, the CRM popup will only appear when the caller’s number matches a CRM contact in the 3CX dialer and the call is answered. (The popup is not opening on ringing).
The Lookup option is only available when the "Opent Contact in Supported CRM" is selected. (PWA > Settings > Integration)
Can you please confirm that this is the case for you?
Hi @reynolwi,
I am using the server-side option.
If I type in a phone number in the dialer, it is correctly looking at Dynamics 365 as I indicated there.
It simply refuses to appear on inbound calls, create activities for phone and text messages on existing contacts, or create new contacts as leads.
Check my suggestions, if it doesn't work adjusting the matching strategy, the logs will give you the answer.
arneg
