Solved Editing a custom template for a GXP2200EXT
Moz
Hi All,
Trying to enable a Grandstream expansion module (GXP2000EXT) on a GXP2140 phone using a custom template.
I have copied the template, renamed it then copied the content to Notepad++ to adjust.
What values should I add and where?
Looking to add BLF to a particular EXT named accordingly (firstname lastname)
Is it as simple as adding 1 where %%value2%% shows in this example: <P23000>%%value2%%</P23000>
<!-- # EXT 1 -->
<!-- # Key Mode. -->
<!-- # Number: -1 - 20 -->
<!-- # -1 - None, 0 - Speed Dial, 1 - BLF, 2 - Presence Watcher -->
<!-- # 3 - Eventlist BLF, 4 - Speed Dial via active account, 5 - Dial DTMF -->
<!-- # 6 - Voice Mail, 7 - Call Return, 8 - Transfer, 9 - Call Park, 10 - Intercom -->
<!-- # 11 - LDAP Search, 12 - Conference, 13 - Multicast Paging, 14 - Record, 15 - Call Log -->
<!-- # 16 - Monitored Call Park, 17 - Menu 18- XML Application,19 - Information, 20 - Message -->
<!-- # Mandatory -->
{IF blf47}
<!-- # Account. 0 - Account 1, 1 - Account 2, 2 - Account 3, 3 - Account 4, 4 - Account 5, 5 - Account 6 -->
<!-- # Number: 0 - 5 -->
<P23001>0</P23001>
<!-- # Description -->
<!-- # String -->
<P23002>%%label%%</P23002>
<!-- # Value -->
<!-- # String -->
<P23003>%%type%%</P23003>
{ELSE}
<P23000>-1</P23000>
<P23001>0</P23001>
<P23002></P23002>
<P23003></P23003>
{ENDIF}
Thanks,
Hi All,
It turned out that I did not have to modify the template.
Adding BLF to row 15 and below in the extension BLF in the 3CX management console worked.
Glad to see the issue has been resolved and thank you for updating the thread with your solution .
Rhameez
