Solved Emergency Call Hotdesking
Fábio Ernando
Platinum Distributor
Good Afternoon.
The hotdesking function todays allows dialing only to login an existing extension... Is there any possibility of enabling ooutbound rules for emergency calls?
Te ideia is that in a company that owns extensions hotdesking, when an emergecy call, make that call without logging the extension first before making that cal...
According to this https://www.3cx.com/docs/hot-desking/ , emergency numbers defined in Settings->Emergency Numbers will work even when the extension is logged out.
A device currently not used by a user can’t make outbound calls, unless the number is defined as an “Emergency Number”.
That should be: Settings->General->Emergency Numbers
Reactions: Fábio Ernando
Hi mark. Thanks, I took the test according to the documentation and it worked normally.
GP Concepts
