Emergency Numbers offloaded to GSM dialer. Cannot find the setting.
sanxion
I have a Samsung Galaxy S10 up to date with latest OS (Build Number : G973FXXSGHWC2)
3CX App on Version 18.1.3.135
I cannot set the setting for 'Emergency Numbers offloaded to GSM diale' in Settings > Accounts or in Settings > Advanced for "Emergency Numbers offloaded to GSM dialer"
In this 3CX blog it states it's been added:
https://www.3cx.com/blog/releases/android-12l/
This was Feb 2022. I can see it on my iPhone 3CX app, but I cannot see this feature in the 3CX app settings.
Can anyone help out and let me know where this setting is located.
Hi @sanxion
Thanks for your feedback.
Firstly could you confirm that your android device has a sim card installed?
If so, please wait for the next release that we are currently in the process of rolling out which might fix your issue.
Hi @ThomB_3CX
Yes, how silly of me! :oops:
This is a test device and it does not have a SIM!
I will try it on another Android with a SIM.
Hi @sanxion
ARKC
