- Joined
- Sep 22, 2020
- Messages
- 44
- Reaction score
- 3
- 3CX Version, e.g. 18.0.3.461 / 18.0.4.965
- Server OS, Debian 10
- Is the 3CX Server Hosted and where? Azure
We have an issue with a particular PBX backup (to FTP) failing when including recorded calls and password protection. I suspect this is an issue with the backup size as the error below seems to indicate, however there is 200gb free on our ftp and an unencrypted backup is only 7gb. I understand encrypting it increases the file size but surely not by that much. If I untick call recordings then an encrypted backup will succeed with a size of 1.2gb.
Recordings are stored on a secondary vm disk if that matters
Code:
Your 3CX backup failed due to the following reason(s):
System.IO.IOException: Entries cannot be created while previously created entries are still open.
at System.IO.Compression.ZipArchive.AcquireArchiveStream(ZipArchiveEntry entry)
at System.IO.Compression.ZipArchiveEntry..ctor(ZipArchive archive, String entryName)
at System.IO.Compression.ZipArchiveEntry..ctor(ZipArchive archive, String entryName, CompressionLevel compressionLevel)
at System.IO.Compression.ZipArchive.DoCreateEntry(String entryName, Nullable`1 compressionLevel)
at _3cxNetBackupAndRestore._3cxBackup.CreateEntry(String name)
at _3cxNetBackupAndRestore._3cxBackup.ZipFile(String dst, IFile src)
at _3cxNetBackupAndRestore.BackupTasks.BaseFilesTask.BackupFiles()
System.IO.IOException: No space left on device
at System.IO.FileStream.WriteNative(ReadOnlySpan`1 source)
at System.IO.FileStream.WriteSpan(ReadOnlySpan`1 source)
at System.IO.FileStream.Write(Byte[] array, Int32 offset, Int32 count)
at System.IO.Compression.DeflateStream.WriteDeflaterOutput()
at System.IO.Compression.DeflateStream.PurgeBuffers(Boolean disposing)
at System.IO.Compression.DeflateStream.Dispose(Boolean disposing)
at System.IO.Stream.Close()
at System.IO.Compression.CheckSumAndSizeWriteStream.Dispose(Boolean disposing)
at System.IO.Compression.ZipArchiveEntry.DirectToArchiveWriterStream.Dispose(Boolean disposing)
at System.IO.Compression.ZipArchive.WriteFile()
at System.IO.Compression.ZipArchive.Dispose(Boolean disposing)
at System.IO.Compression.ZipArchive.Dispose()
at _3cxNetBackupAndRestore._3cxBackup.FinishingTask()
