Solved Error during provisioning 3CX
the_jackal_br2001
Forum User
Hi team,
I have this problem today when provisioning the 3CX in VPS.
System.Exception: Error in CreatingCloudServerManagementDatabase.sql: 22023: new encoding (UTF8) is incompatible with the encoding of the template database (SQL_ASCII) ---> Npgsql.PostgresException (0x80004005): 22023: new encoding (UTF8) is incompatible with the encoding of the template database (SQL_ASCII) at Npgsql.NpgsqlConnector.<>c__DisplayClass160_0.<g__ReadMessageLong|0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at Npgsql.NpgsqlConnector.<>c__DisplayClass160_0.<g__ReadMessageLong|0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at Npgsql.NpgsqlDataReader.<>c__DisplayClass41_0.<g__ReadMessageSequential|0>d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at Npgsql.NpgsqlDataReader.NextResult(Boolean async, Boolean isConsuming) at Npgsql.NpgsqlDataReader.NextResult() at Npgsql.NpgsqlCommand.ExecuteReaderAsync(CommandBehavior behavior, Boolean async, CancellationToken cancellationToken) at Npgsql.NpgsqlCommand.ExecuteScalar(Boolean async, CancellationToken cancellationToken) at Npgsql.NpgsqlCommand.ExecuteScalar() at PostInstall.DBConnection.ExecuteScriptInternal(NpgsqlConnection connection, String sqlQuery, IDictionary`2 parameters) at PostInstall.DBConnection.ExecuteScript(String sqlQuery, IDictionary`2 parameters) at _3CXCloudDBManager.DbConnectionExtensions.ExecuteScript(IDBConnection connection, Object configurationStructure, String scriptText, Boolean asResourceName) Exception data: Severity: ERROR SqlState: 22023 MessageText: new encoding (UTF8) is incompatible with the encoding of the template database (SQL_ASCII) Hint: Use the same encoding as in the template database, or use template0 as template. File: dbcommands.c Line: 383 Routine: createdb --- End of inner exception stack trace --- at _3CXCloudDBManager.DbConnectionExtensions.ExecuteScript(IDBConnection connection, Object configurationStructure, String scriptText, Boolean asResourceName) at _3CXCloudDBManager.CloudDBManager.CreateCloudServerManagementDatabase(IDBConnection superuser, CloudServerManagementDatabaseConfiguration configuration) at PostInstall.SetupExecutor.CreateCloudServerManagementDatabase(CloudDBManager cloudDbManager, DBConnection templateConnection) at PostInstall.SetupExecutor.CreateDatabase(Action`1 stateChanged) at PostInstall.SetupExecutor.ExecuteSetup(SetupSettings setupSettings, Action`1 stateChanged, Action`1 errorNotifier) at PbxWebConfigTool.PbxSetupService.CreatePbxInternal(SetupSettings settings)
OK
We might nee more information on the matter first:
• Is this a new installation?
• Where are you seeing this error?
• If yes, how did you deploy was it via the 3CX Customer Portal or the Marketplace?
• At what step did you get this error?
• Did you try to restore a backup?
Please let us know what exact steps you took so that we can better understand the situation.
Reactions: ChrisC_3CX
GP Concepts
