- Joined
- Sep 13, 2022
- Messages
- 10
- Reaction score
- 2
I will share with you a problem that I encountered while using on-premise (Window server) for recording archiving. The error message that I received was:
This error indicates that there was a problem with the SFTP connection between the local server and the remote server. It seems that the SFTP session could not open the file on the remote server for some reason. This prevented the recording archiving from completing successfully but 3CX server cannot remove recording file on this server. .
I tried to troubleshoot this issue by checking the following things:
- The network connectivity between the local server and the remote server
- The SFTP credentials and settings on both servers
- The permissions and ownership of the files and folders on both servers
- The firewall rules and antivirus software on both servers
However, none of these steps resolved the issue. I was still getting the same error message every time I tried to archive the recordings.
I searched online for similar problems and possible solutions, but I could not find any helpful information. please help.
Code:
Recording archiving failed due to the following reason: Renci.SshNet.Common.SshException: Bad message at Renci.SshNet.Sftp.SftpSession.RequestOpen(String path, Flags flags, Boolean nullOnError) at Renci.SshNet.Sftp.SftpFileStream..ctor(ISftpSession session, String path, FileMode mode, FileAccess access, Int32 bufferSize) at _3cxFilesystemImplementations.SFTP.SftpFolder.CreateFile(String name) at TcxRecordings.RecordingData.Archive(Boolean justUpload) at _3cxSystemService.AutoArchiving.DoArchiving(CancellationToken cancellationToken)
