Error when Importing Contacts in Personal Phonebook
simalis
SMB User
I am unable to import to my personal phone book with a csv file.
I downloaded the sample phonebook CSV. I entered my contacts, a list of 405 Contacts. I already have a couple hundred contacts.
Is there a limit, where if you have 500 contacts already you cannot import anymore, you can only manual add?
It works when I import a file that leaves me with under 500 total contacts in 3cx. Over 500 it gives me error.
My company and I have 3CX SMB FREE. Version 20.0 Update 7 (Build 1057)
Hello @simalis ,
I do think the error message is clear.
"Maximum number of rows permitted is 500"
You will need to upgrade you license to overcome this.
Paulo
Are you sure that changing the version is enough? I have a 16 simultaneous calls Enterprise Multi-tenant license, and I’m also facing this 500 limit during import.
Multitennant has this limit, SMB is also multitennant
Reactions: paulodagraca
Netflo
