Solved Eset blocks *.3cx.be domain
NikosT_3CX
Staff member
3CX Support
We have been contacted regarding an alert where Eset blocks the " *.3cx.be " domain.
The alert has been reported as "incorrectly blocked page" to the vendor by the customer.
All incorrectly blocked FQDNs can be reported here: https://webfilter.eset.com/en-us/remove
We will post here any further updates.
Our communication will remain transparent throughout this investigation.
It seems that Eset has cleaned up the domain *.3cx.be.
You may check your FQDN here: https://www.virustotal.com/gui/home/url
Note: if you do not use port 443, and you use port 5001, define it on the URL, the search will be faster.
Up to now no further requests came to our attention for this.
Since the AV provider ( Eset ) whitelisted the domain again, we will mark this thread as Resolved.
BConveryCoreCare
