Exception: ParseException
massimo_mic
on activity log i see sometime this message:
04/04/2019 09:38:14 - Exception: ParseException e:\jenkins\workspace\16.0\rc\sources\3rdparty\resiprocate\rutil\parsebuffer.hxx:230, Parse failed unexpected eof in context: 44 ^ @ e:\jenkins\workspace\16.0\rc\sources\3rdparty\resiprocate\rutil\parsebuffer.hxx:230
04/04/2019 09:38:14 - [Flow] Target endpoint for 44 can not be built!
What specific version of the PBX are you using?
This is just an error that is generated when, in one example, the destination could not be reached for some reason (depending on the case).
Windows version v16
phone on system have PIN protect enable, is possible this error occour when user don't insert PIN or insert incorrectly?
You can safely ignore the error if you are not facing any issues, it's just showing developer information about which component of the PBX generated the error. Yes it can be generated when the PIN is wrong like my example below. I tried to call 17777777777 without calling the PIN IVR first and this happens:
Code:
04/04/2019 14:54:09 - Exception: ParseException e:\jenkins\workspace\16.0\rc\sources\3rdparty\resiprocate\rutil\parsebuffer.hxx:230, Parse failed unexpected eof in context:
17777777777
ok Thanks for information
LBS Care
