Export configuration file (xxxx.3cxconfig) of all extensions
slxda
I am looking for a solution to export the configuration files (.3cxconfig) of all 3CX extensions for provisioning Desktop APP, without sending them by email.
There is a way to do it, by API maybe.
Thank you for your help.
It is not possible to download the config files for the extensions without sending a welcome email.
The 3CX Desktop app cannot be configured using that config file, it can only be configured using the web client.
Thank you for you response, however we configure 3CX App on windows with the configuration file received from welcome mail.
I needed all the configuration files in order to automate the configuration of 3CX App on the workstation, since we cannot connect in SSO on 3CX App Win
When you say 3CX app for windows you mean 3CX Phone for windows V16?
If possible send us a screenshot of the client.
Yes sorry i mean 3CX Phone for windows.
I would like when the user logs in to Windows I send their .3cxconfig to start/configure 3CX Phone for Windows, for this I need all 3CX extensions configuration files.
If I can't export them, I'll email them to myself.
From what I understand what you are trying to achieve is for any user to log in to any computer and have their 3CX app pre-configured and ready to use, is this correct?
If so, please note although this is out of the scope of 3cx as it is relevant to AD/Networking, we can suggest the following.
Since the profiles for the 3cx app on Windows are saved within the users roaming profiles, in the location "C:\Users\%username%\AppData\Roaming\3CXPhone for Windows", you can use roaming profiles available within an AD domain to achieve the above requirement.
Also please note that the 3cx app for Windows (formally known as 3cx phone for Windows) is now legacy and which means no further development will be given to this application and we suggest using the desktop app instead.
Thank you for your help, you understood the need.
I will integrate authentication with M365 and use Desktop App.
You are welcome!
Glad we could help
fngl
