Solved Ext with two status: A
DaveSD
I have an extension (755) stuck in Do Not Disturb, calls to this extension go directly to vms. The extension shows as available on the web client and queues. I have connected to the extension via the web client and dialed *30, still cannot ring extension. On the mobile app the status for this ext is "Available, Do Not Disturb"
See image, can anyone explain this multiple status?
Thanks much
Hello @DaveSD
Looks like you accidental triggered the legacy DND type. Try dialling *60 and see if that works
This was it! I had a sales person who was using the old codes.
Thank you!
~David
Bluebox Global
