Extension calls mobile and show extension number?
ericmachine
Hi everyone,
Like to check.
Assume my hunting number is +6065XXXXXXX and extension is 100.
When I call someone on a mobile phone via my bria3 softphone, I want my hunting number and my extension number to show up?
This will apply to all my users who have extensions.
Any way to configure this on elastix?
Thank you.
What you can do is to configure the outbound callerID on your extension, that number will be used as your callerID when calling an external number.
Beware... if you use an incorrect number/incorrect format, your telephone provider will drop your call (it is a mechanism to avoid spoofing), if you use an analog provider, they will overwrite your numbers.
so I can show like this on the calls to mobike phone?
"035XXXXXXX ext 100" hmm? can that work?
035XXXXXXX is our hunting number, we just append something behind?
iamatlas
