Extension connected (green chip) or disabled (red chip).
ClercGA
Gold Partner
To avoid consulting n pages in the window "extensions in the 3CX dashboard".
In the "extensions .csv" file, what is the name of the column that indicates whether the extension is connected (green bullet) or disabled (red bullet).
If the information does not exist, in which PostgreSQL table is it located?
If not, is there any software under Linux that can give me the information?
Thank you in advance for your answer.
Best regards.
Translated with www.DeepL.com/Translator (free version)
There's no field for that. Green means it has a phone or app registered, or Ring mobile simultaneously is enabled (which "fakes" the registration.)
Red means it's completely offline.
StevenWillems
