Solved Extension locked in DPD ? state
saba
the main operator used the *32 by mistake and locked her phone in a DND ? state, but i can t change the status. i try *30 the system say it 's availbale but the extension is still locked
13298
thx
What brand phone are you using?
Try login to the phone by web browser and see if you can disable it
Hi Saba
Dial the following on the phone * 30 and after this also dial * 60
Also tell the operator to avoid using * 61 in the future, its an old DND mode that is no longer supported. They should only use the *3[0-4] profiles to set DND or just use the button on the device.
Reactions: JohnS_3CX
Glad to help!
Kayla Norris
