Solved Extension report question
treboR
Forum User
When running the extension statistic report, in the Outbound column for answered and unanswered, how can there be unanswered calls if no outbound calls are made?
Well, we see here that outbound calls were indeed made. The first row did 9 and they were all unanswered.
I see nothing wrong here. Unless you're telling me these extensions never made outbound calls. To which I would reply: are you sure?
Reactions: Cal4care | RA
Thanks, this helps...
GP Concepts
