Extension Status's
tim.goodacre
SMB User
Hi guys.
I have a system setup using extension schedules to change the voicemail announcements at different times of the day
Status 1 Available - Call Queue throughout the day
Status 2 away - Lunch and Close of Day
I would like to do 3 status for three different voicemail announcements;
Status 1 Available
Status 2 Away
Status 3 Lunch
Can this be done without using call flow designer.
thanks
Any help would be hugely appriciated.
This is possible with statuses or even exceptions to route calls based on times but you may also consider the new group office hours scheduling.
See this guide here
HI Charles thanks for the reposne.
Currently on the voicemail ext I have Call forwarding switch status enabled. So available will use the available annoucement in the forwarding options and the break settings is set to away. Is there a away to set a third status?
You can set a 3rd status and that is the DND status, which can also be switched to automatically during out-of-office hours, when the extension is set to auto-switch.
Im guessing doing that through adding a second break on the extension schedule?
sherry reynolds
