Extension to Extension calls only ring once
it26
Very odd issue here. We have one extension that when receiving a call from an external caller rings the full 40 seconds (we set the ring time). But when a caller from a local extension calls, the call only rings once, the red light flashes the rest of the 40 seconds. THis only happens extension to extension and only to this one extension. Help.
TIA, Larry
If the red light is still flashing, then I have to assume that the set is still ringing (does the caller still hear ring-back?). the fact that the audible ringer isn't sounding, would suggest it is a set issue. Perhaps an option.
The phone rings once if its an extension to extension call. The phone rings normally of its from an outside caller. Therefore I don't think it's a set issue.
Is this the only set affected? What make/model phone is this? Does the caller continue to hear ringback tone, meaning the set is still ringing? Does a 3CX Activity log, for an external call, and an internal call, look the same?
I suspect some set option, dealing with audible ringing, that is being "activated" on internal calls only..
Yealink T42S. Yes, the caller continues to hear the ring-back tone and if the extension user sees the red light flashing on the phone they can still answer it befor it goes to VM. Logs look the same for both.
I set all to Ring1 and reprovisioned the phone, tested and same issue.
Are you using the same type of set at other extensions? Have you tried swapping sets? Firmware level is the same on all sets?
Yep. Set is the same at all stations, and so is firmware. Maybe its an issue with the extension?
It might be a hardware issue. Swapping with another set should confirm that.
Hello, I'd that issue with snom phones and NFON PBX (not 3CX). No one could help me, even not snom. The solution was to Change the ring tone. I think it was set to Ring tone #5 and this was just really a "Special Ring tone" ringing only once... In Addition: I only saw by change that the selected Ring tone #1 wasn't applied. This PBX had three ringtones: Internal / External / Queue. Call came by queue and Ring Tone #5 was applied in that case.
Maybe this helps...
Wecare_ITA
