Extensions shutting down
Julianb
New User
the problem is that 3cx extensions and services have been going offline every night since the day before yesterday. and every time I have to restart the raspberrypi where can i find the logs so i can send that here
Hi @Julianb,
Do you receive an email stating which services are shutting down nightly? Do you know what time this is happening?
You can generate Support Info by clicking Support in your Management Console. Click Generate Support Info and PM me the zip file.
The following service(s) were interrupted:
3CXIVR01
At 05:31 amsterdam time
Hi @Julianb,
Are there any core or dump files in /var/lib/3cxpbx/?
does that have so many influence? and is there an backup and restore option thaT EVRYTHING backs up eveb passwords and restrores them
Yes, I believe that installing a more resource intensive OS would have an influence. The PBX was tested on the Pi and the supported method of installation developed, thus its advised to follow it.
The backup and restore function in the Management Console outlines all criteria that can be backed up and restored. You can reset the password before backing up and reinstalling, by navigating to Security >> Security Settings then Admin Credentials and resetting the password.
If you do not remember the password, there is a management console "Forgot password" link that appears after entering the correct username but incorrect password twice (note, the third time will force a lock out).
lukas1103
