Solved External Call in audio conference
Giotta
Titanium Partner
Recently discovered a bug in the system.
When I make a conference call, starting with an external number and adding an internal extension it works correctly, but if I start with an internal extension and try to add an external extension I get an error.
This case only occurs when I use the softphone by clicking the conference button, If I try to do it in other ways, the conference works.
3CX Version: 16.0.676
Hi @Giotta
You probably don't have an outgoing rule for the system extensions and the conference server cannot dial the external number.
Add an outgoing rule that is not limited by extensions or groups and try again. I can replicate your exact behavior and rectify it by creating the rule.
Note: This requirement has arrived with V16. Check here, especially slide 10 that includes a blocking rule and then a system extension rule https://www.3cx.com/3cxacademy/videos/advanced/configuring-outbound-routing/
Thanks for the answer,
I created the rule and it worked.
Glad to hear it works
Roman Mazur
