Fail to receive calls on SIP trunk after upgrade to v16
Sobhi
Hello all, i need help with this issue
I have Generic SIP trunk where i just receive calls on it,
After upgrading to v16 the the pbx reject the calls and i can't solve this issue,
this is from Activity tab:
111.111.111.111 is my provider IP
222.222.222.222 PBX IP
04/09/2019 6:24:48 PM - Malformed SIP request received:
BadSip Recv Req INVITE from 111.111.111.111:5060 tid=bb3.90607631.0 [email protected]:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 111.111.111.111:5060;branch=z9hG4bKbb3.90607631.0
Via: SIP/2.0/UDP 333.333.333.333;branch=z9hG4bKbb3.f1ba1c147b3b2101fa24a36c514b7f01.0
Via: SIP/2.0/UDP 444.444.444.444:5060;branch=z9hG4bK114F02C1190
Max-Forwards: 68
Record-Route: <sip:111.111.111.111;lr;ftag=64D099F4-1D5E>
Record-Route: <sip:333.333.333.333;lr;ftag=64D099F4-1D5E;vst=AAAAAAQFAQQFAXkBCQAaDAAadQAWBx8FMC4xMjYuMTAx>
Contact: <sip:[email protected]:5060>
To: <sip:[email protected]>
From: "447848314974" <sip:[email protected]>;tag=64D099F4-1D5E
Call-ID: D3E249D1-5A1A11E9-BB5DF2D0-C28BF832@444.444.444.444
CSeq: 101
INVITE Expires: 180
Min-SE: 1800
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Content-Disposition: session;handling=required
Content-Type: application/sdp
Date: Tue, 09 Apr 2019 16:24:48 GMT
Supported: 100rel, timer, resource-priority, replaces, sdp-anat
Timestamp: 1554827088
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow-Events: telephone-event
Remote-Party-ID: 447848314974
Cisco-Guid: 3554782633-1511657961-2279014424-0419390928
Content-Length: 265
v=0
o=CiscoSystemsSIP-GW-UserAgent 5475 1935 IN IP4 444.444.444.444
s=SIP Call
c=IN IP4 444.444.444.444
t=0 0
m=audio 17502 RTP/AVP 8 0 101
c=IN IP4 185.40.126.108
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
Any help with that issue
Otherwise i will downgrade to v15
Who is the provider? Perhaps others have had the same issue, and found a solution.
Reactions: Sobhi
Is it a trunk from another PBX?
Because I can;t see the original IPs (and perhaps phone numbers), I can't be certain...but there appears to be 3 numbers and more than 3 IP's involved.
...along with the malformed SIP request, I have no idea. You would have to compare an Invite with one when it was working (which you may no longer have), to see the difference.
Reactions: Sobhi
The calls forwarded to us from Cisco SIP domain,
There is no account user or password.
Just they are forward the traffic and i created trunk on my 3CX for the DID
fransisco
