Maybe if your system has trouble contacting the Google PUSH servers, usually might happen if you have a strict firewall which sometimes decides to block traffic while other times it lets it pass through.
Thanks for sending us the logs required to look into the issue
After further investigation, we concluded that this most probably is a connection issue
When trying to send a push message to https://fcm.googleapis.com/fcm/send, the server closes the connection, or perhaps something in the middle (bad internet connection).
In our logs, we got an exception: SocketException (104): Connection reset by peer which shows this.
