Failover Documentation Update
cobaltit
Platinum Partner
When working with a customer it was brought to my attention that the failover documention needs to be updated. The 'Apply' button referenced in this step no longer exists on v16 Update 2:
Code:
Step 2: Configuring the Passive Server (#2)
Important: For scenarios where the Active and Primary Servers are behind different Public IP addresses, when you first complete the installation of the passive server and you run through the installation options, your Public FQDN will be rewritten to the Public IP of the failover server. To re-write your External FQDN to resolve back to the Public IP of the Active Server you will need to go to your primary server press to edit the license and then hit Apply so that the FQDN is switched back to the 3CX Active server and restart its services.
I advised to my customer to click 'Edit' and then 'Ok' which I believe has the same effect.
@JohnS_3CX @YiannisH_3CX Can you confirm this does have the same effect, and can you direct someone to update the documentation?
Reactions: YiannisH_3CX
Hi @cobaltit
Thank you, we will make note of it to be updated.
Smax
