Solved Failure install 3cx on Debian 10
deepee
I am not 100% sure about this specific error, but currently 3CX is only supported on Debian 9 Stretch.
Debian 10 support is still in technical preview state.
Oh and i just noticed you missed something in your first line.
It should be:
Code:
wget -O- http://downloads-global.3cx.com/downloads/3cxpbx/public.key | sudo apt-key add -
How do I just install the normal / latest version?
I have triggered a Debian 9 reinstall of the VPS and will try again. I have 6 other 3cx installs with Debian 10 which installed no issues?
That's not a good idea for now - they are not considered stable releases
Ignore my stupidity, I had actually used Debian 9 (stretch) and assumed I had used Debian 10. I am installing on Debian 9 now and it seems to be working fine... :rolleyes:
No worries, glad to hear its working fine
footandankle.my3fcx.us
