- Joined
- Dec 2, 2015
- Messages
- 1
- Reaction score
- 1
Check if the device has a uaCSTA setting that might be disabled. 3CX uses CSTA to sync the DND status.Early testing and my feedback is it's an excellent handset. You need to tweak the web interface directly to make the DSS keys available whilst in a call (so that you can transfer to them), shared parking also works well using the same method. Currently the only issue I've found is that DND isn't synced to the 3cx server like it is on Fanvil desk phones and other handsets and app (essentially it's just local DND to that device), hopefully this will be fixed in a future update.
Thanks for the suggestion, yes it does have that setting, but I'd already enabled that (well to be fair it was on by default).Check if the device has a uaCSTA setting that might be disabled. 3CX uses CSTA to sync the DND status.
Hi,I have been testing this unit out, but it seems to goto sleep and then doesn’t ring, until you press a button to wake it, anybody else seen this?!
Thank you very much for your cooperation. I have tested the W611W with this template and it works fine. GreetingsHi, ive just written the fanvil support and its awesome! They respond verry quick and sends me some .xml file.
It works fine - ive just modified the blf section because in the original file there was only 1 blf implemented. Ive doubled it to 64 blf keys.
Also the given default background image is not implemented into the 3cx (file is missing into the system) but i think with enterprise edition there is no problem to set one.
fanvil_phonebook.xml will implement as local phonebook into the w611w at the moment.
i think together we can improve the function of this template.
Progress, but the BLF buttons are not available. I'm using the latest firmware 2.12.5 series, and have used the latest template you provided. Any hints?I have been using the W611W since December.
If you are having issues with the BLF buttons you need to use the newsest template and also update firmware (2.12.4.14 or newer). Thats how i fixed the problem with fanvils help in Jan 2023.
I am using it daily with 3CX Ent V18 and it is a very nice product. Sound is great and very robust.
The only issue is that 3CX has not yet officially supported this phone and that is why in the dashboard of 3CX you keep seeing a red alert.
I an running V18 Hosted.this is the updated template currently in use
If Hosted means 3CX hosted then you can'tI an running V18 Hosted.
Hi,this is the updated template currently in use
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
