Fanvil DoorPhone i10X URI not working (ConfigManApp)
chance-wmt
curl -u admin:XXXX -v http://192.168.1.2/cgi-bin/ConfigManApp.com?key=F_LOCK&code=#
This is not triggering the relay, however it returns with HTTP/1.1 200 OK
Odd... Even tried without login. If I use the wrong login it fails as it should. If I call the DoorPhone and send a DTMF # it works so it's the correct code and it is not broken.
I can run cgi-bin/ConfigManApp.com?key=999;ENTER and it dials Voicemail so I know for sure Action URI is working.
I believe you will find Fanvil uses a different code for opening the door via keypad VS via phone call.
Reactions: chance-wmt
I am using an unsupported model Fanvil i10V, but I'll keep this in mind for later
I found it, (/cgi-bin/ConfigManApp.com?egs&output1=OUT1_SOS)
Example:
Code:
curl -u admin:admin -v "http://192.168.1.2/cgi-bin/ConfigManApp.com?egs&output1=OUT1_SOS"
Reactions: JohnS_3CX
Diogo Maia
