Fanvil i12 Door Phone
Jason Aday
Gold Partner
I know the i12 isn't on the supported list, but wanted to see if anyone was using it. We have 3CX version 15.5 SP6. The door phones will register and work just fine until they are rebooted, once rebooted, the VoIP status shows "unapplied" instead of registered. They go into a constant reboot loop, the only way to get it out is to be quick and clear the etc file so it factory defaults back. I can reconfigure them and they will register and work just fine, until rebooted. Has anyone seen this behavior? They are running the latest firmware available on Fanvil's site. The door phones are showing up as New under the Phones tab, but they are registered according to the Extensions tab.
Thank You,
Jason
