Fanvil i16S wont shut up..
Alphabetic
3CX MVP
Hi all.
we've had this fanvil installed for months if not a year or so and it's started doing this beeping.
there's no configuration out of the norm other then setting the release key.
i've reset this phone.
any ideas why it does this noise?
https://filebin.net/7bmxhq5bwhi4sjye
The sound this is making sounds like the call button was pressed. Is this not the case?
this is the noise it makes after the release key is pressed.
I would recommend checking and ensuring the firmware is correct, and then, since this is related to the device itself, contact Fanvil support for further assistance.
LeeonLau
