Fanvil i62 - opens the door after reprovisioning / reboot
MEN
Good morning,
in a site we have installed 2 Fanvil i62 with firmware 2.12.52.23 under a 3CX V 20.0 Update 9.
This saturday at 12:28 and 12:29 the intercoms make a reprovisioning with 3CX and with that they switch the state of the relay (like one person press the internal exit button) and open the doors
i62-2
i62-1
This morning I make some test and when I reboot the i62 it open the door... Is it normaly?
This question is best suited for Fanvil Support directly.
3CX provisions the device to work for SIP with your PBX, but the template and the device firmware behavior is handled by Fanvil. But it could also be related to your wiring type (normally open or normally closed style relay), possibly you wired it in the opposite of what you intended? Some lock types are designed to open the doors when the power is lost (as a fail safe) and others are designed to stay locked when power is lost. During reboot, the power to the relay of the Fanvil will be lost.
Please contact their support direct for specific assistance on this matter, and let us know also if you have any useful feedback.
LeeonLau
