Fanvil PA2 Setup
[email protected]
I purchased a Fanvil PA2 with an external speaker. I have it setup, but I can't find any documentation to set this up so when i call it, it will broadcast what I say over the speaker. Pretty simple, but I can't get it to work. Please advise how to do this.
Thanks, rgruber. I watched that video, but he is using the PA2 to take a mic and play it on extensions, I want to hook up a speaker, call an extension or page group, have the PA2 pick up and broadcast what the person says into the phone. Any help is appreciated.
I'm assuming you can either intercom it or there is an auto-answer setting in the web interface. If you want to buy me one I'll read the manual and test it for you. You can also try Fanvil's support. This isn't really specific to 3CX.
I opened a case with Fanvil, but I was hoping someone on here could help.
UPDATE: I did a factory reset and auto provisioned the PA2, and it worked as expected!!!
hughesdouglas
