Solved Fanvil V62W Support
Anthony - Sedcom
I have just deployed a 3CX system with V62W
I have found a couple of things
First off - The V62W is not the same as the V62
The V62 is a 6 DSS Key phone with a Black and White screen
The V62W is much like the V63 but ladled as a V62W and has 8 DSS Keys and a Colour Screen
So Yesterday I found the phone will connect and work with 3CX as a Fanvil V62 but DSS Keys 7 and 8 will skip and will not fill automatically
And you will also not get a 3CX desktop pic nor Custom image if set
Today playing around you can Register the V62W as a V63 (3CX does not have V62W support yet next thing to address) The V63 will fill out the DSS Keys no issues and give you the 3CX Logo
Now Support - 3CX when will the V62W become a supported phone along with allow Fanvil's to be a router phone on WIFI????
The specific model is added in the latest Update 5 BETA versions:
Do we have a Time line on Beta coming out as I currently see no updates for this?
Also the question to allowing Fanvils with WIFI to work on Wifi as a router phone??
Note: myself will not be running A router phone on wifi with other phones on it.
It will more be for users at home with a phone on WIFI?
Noting also the Yealink T5*W phones are able to be router phones on Wifi (just tested myself and worked)
This model among others are added in the Update 5 Beta:
Currently the latest update is in Update5 Beta2
More information and guidelines will be included in the stable version update.
V20 Update 5 final has now been released, so if you wish to add one of those models please go ahead but make sure to install the supported firmware first before you attempt to provision it.
https://www.3cx.com/docs/phone-firmwares/
Note: Router mode is only tested and certified to work on LAN.
LeeonLau
