Fanvil X5U saying Sip Register Failed
LeeContracting
Forum User
I had set up a 3cx system for another company I support. It worked just fine. I'm trying to configure a new system and using a Fanvil X5U phone on a hosted StartUP. The company has less than 10 users that will need phones. When I have the phone started up it just goes to a screen where I select my language which is English. I can then get to the web portal of the phone. I see on 3cx it says the phone should ask for a user id and password but it's not. I need to get this configured and my error seems to keep being the same no matter what I do. Sip Register Failed. Any pointers?
I have the Fanvil X5U... how do I determine if it is the V2. There's a difference? If so I'm confused because I copied and pasted that and purchased it online so. It seems weird that the X5U would be different than the X5U-V2 where as only one of them would be able to be used as a router phone. That all being said we did not set up an SBC on-site as this is going to be very minimal. They will have at most 4 users. Currently only two phones are configured on the running PBX system. I'm trying to migrate that to 3cx
Thanks for the reply.
To identify if the Fanvil is a V2 capable of being used as a router phone, check the back of the Ip phone for the sticker that states the model below the model number, and you will see Rev: B-Pro. If so, you can provision this IP phone as a router to connect it to one of the extensions and then use it to provision the others as normal phones behind it to your 3cx start-up.
If it is not a V2, it will state Rev: A, for which you will need a separate 3cx SBC to provision the IP phones.
Hi, Ive just done this myself and it was quite easy. I have the same phone, version 1. Have a look on the back on the phone and it should say X5U Revision A which I assumed meant V1 of the phone. I added the phone in 3CX and set the provisioning method to STUN remote. making sure to put the correct MAC address in as well. I rebooted the phone and when finished, it asked for a login. I put the ext number, in my case, 100, and then the voice mail pin. Then it did the rest for me!
Otherwise I have also done this by installing a 3CX SBC on site, also easy.
Please note that stun provisioning is neither an option or supported with startup, you need an sbc!
Reactions: JohnS_3CX
Ive got startup, why does it work for me?
What is working please? IP Phones provisioning as remote stun to 3cx startup?
I do have a X5U V2. I have done a factory reset and I'm still not getting the prompt for username and password. I do have that information copied into my machine I'm just not sure where it needs entered since the phone is not actually asking for it. All of the lines show SIP 1 SIP 2 SIP 3 and SIP4. Even after performing a factory reset it doesn't prompt me for a username/pw.
Hi leeContracting
Can you check this guide and ensure that the steps are being followed:https://www.3cx.com/sip-phones/fanvil-x3-x5/#h.2xub9hfvs4dw
Also make sure the firmware is the correct version:
Well it was working up until recently. I am currently having an issue with my provisioned phone is connected but It cant receive or make calls. Is this because of what youre talking about or is it a different issue?
Fixed! Was an issue with the SIP provider.
VAYA
